Re: will a cub one bottom plow fit my farmall A?
Posted by gene bender on April 25, 2010 at 06:10:03 from (207.177.56.155):
In Reply to: Re: will a cub one bottom plow fit my farmall A? posted by James Rumph on April 24, 2010 at 15:02:55:
Something is messed up as the Cub plow has a shorter beam. You could make it work on the A if you had all the rest of the mount stuff Cub used a chain to lift and the A used the rockshaft with some linkage. I have the leveling part of the rockshaft but no linkage to the beam. Yes i mite be interested in some stuff with the exhaust lift but you should make it work on the A just for fun.The lift lever that mounts on the drivers platform makes it hard to het on and off. I built some steos tha help as the same type lever i used for thw rear tooling on the cultivator.
