Re: What is this implement called?
Posted by IH fan on April 25, 2010 at 08:15:41 from (70.242.83.158):
In Reply to: What is this implement called? posted by farmallsuperc on April 25, 2010 at 00:00:06:
Probably different things in different parts of the country... around here it's a "field cultivator"... not heavy enough shanks for a chisel and anything with a single FH point could not pull that many shanks of a chisel. Shanks could even be removed or positioned for a row crop cultivator if needed. I had one similar in a M-F 3 point at one time... guy I sold it to set it up for row crop. I used it to till a big garden.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
