Re: Farmall A info needed
Posted by Janicholson on April 25, 2010 at 09:57:47 from (199.17.6.222):
In Reply to: Re: Farmall A info needed posted by simpsonc9 on April 25, 2010 at 08:44:30:
Check it your self. Help removing it is good if you can get it, or use a cherry picker. Clean the head and be sure all residual gasket material is off.
An aluminum 2' level that is very straight Check it on a surface plate, or other flat.
(or borrow a straight edge from a machine shop)
Place the straight edge across the head and along the head in 5 spots each way. use a feeler gauge between it and the head. If more than .003" in the long direction, or .0015" across, I would have a trueing cut taken. Jim
