Re: 350 gas line
Posted by MN Scott on April 25, 2010 at 10:24:54 from (12.157.197.253):
In Reply to: 350 gas line posted by Wolfhaven on April 25, 2010 at 09:14:00:
You do not need an inline filter. IHC saw fit to just install the sediment bowl with its screen and that system has worked fine for 60+ years. Make yourself a new fuel line out of steel brake line and your problems will disappear. These old tractors should not have rubber fuel line anywhere's in the system, to much of a fire risk. You also mention a vacuum release when you disconnect the line?, check the vent in your fuel cap. They can plug creating a vacuum that will not let fuel flow.
