Re: What is this implement called?
Posted by 36F30 on April 25, 2010 at 10:34:47 from (72.100.19.130):
In Reply to: What is this implement called? posted by Dan J on April 25, 2010 at 00:00:06:
Its a fast hitch toolbar, equipped with coil spring shanks and points.
You bought the toolbar and then you added what you needed. They had adjustable end wheels for it, planter units, coil-spring shanks, stiff shanks, and bedder discs to chose from.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
