Re: IHC UTILITY TRACTOR
Posted by mike paulson on April 25, 2010 at 12:09:15 from (98.15.178.36):
In Reply to: Re: IHC UTILITY TRACTOR posted by lenray on April 25, 2010 at 11:41:40:
what jim is talking about is another pump in addition to the existing pump. the easiest way to do this would be is to stack a second set of controls/valves on your existing control valve or there is another spot right in front of the valve for the fast hitch where you can mount one. they can be bolted to each other(stacked). after adding your second set of controls just run the hoses up front to the loader..you got the pump and you got the resivior as part of the tractor already..
