Re: IHC UTILITY TRACTOR
Posted by Janicholson on April 25, 2010 at 12:38:52 from (199.17.6.222):
In Reply to: Re: IHC UTILITY TRACTOR posted by lenray on April 25, 2010 at 11:41:40:
I assumed the front pump he had was the stock live pump. That being not so, the front pump is probably supplying the original hydraulic system (under the seat where it is normally found) this makes sense if the original failed (as pointed out) or was removed and replaced with a drive housing from a 52 or 53 H or SH. Jim
