Re: Cub Cadet GT2521 not charging
Posted by El Toro on April 25, 2010 at 13:46:02 from (74.103.74.58):
In Reply to: Cub Cadet GT2521 not charging posted by a_lead on April 25, 2010 at 09:17:17:
third party image
Here's a pic. Hal
PS: Use a volt meter set on AC volts. Should get around 30 volts. The outer terminals are AC
and the center terminal is DC and should show 14.5 volts. Run the engine at 1/2 throttle or better. Be careful when doing the checking.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
