Posted by Bob M on April 25, 2010 at 17:00:11 from (74.67.191.214):
In Reply to: Carb Solenoid posted by Bill K Ranch on April 25, 2010 at 16:25:28:
A few possibilities:
1 - Wire the solenoid to the IGN terminal on the ignition switch. Or wire it to the switch side - not the coil side(!) - of the ballast resistor.
2 - Depending on the carburetor you may be able to swap the solenoid for a standard mixture adjustment needle. But don't throw away the solenoid - likely someone out there will want it!
3 - Also depending on the carburetor you MAY be able to back out the solenoid 4 - 5 turns and run the tractor with the solenoid inoperative. (I did this successfully on a friend's 3020 with a Marvel carb a few years ago).
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
