Re: Wiring
Posted by John T on April 26, 2010 at 05:54:30 from (66.244.97.31):
In Reply to: Wiring posted by 706 farmall on April 25, 2010 at 21:43:17:
To add a tidbit to Bobs good advice, in the event the Gennys terminals arent clearly labeled (often stamped in), on many the ARM post is larger then the FLD post. If thats not so and theres no labeling, post back for an ohmmeter method to determine which is which.
John T
