Re: IHC UTILITY TRACTOR
Posted by Wardner on April 26, 2010 at 08:08:09 from (207.69.139.140):
In Reply to: IHC UTILITY TRACTOR posted by lenray on April 25, 2010 at 10:57:06:
I am not familiar with the Utilities but I believe there is only room for two IH valves on the right side of the underseat reservoir. It appears that you need three valves or an aftermarket double selector valve that will shift hydraulic power to another valve or valves. They are kinda expensive and require six hoses for the six ports. Plus they require you to operate the selector before operating the other circuits.
The picture below will do the same job and be much cleaner. It is an IH part for adding additional aftermarket valves wherever you want. Two hoses will supply a double spool remote valve for the loader. It replaces the end cap on the IH valve you already have.
Part # is 365912 R1. I think they are rare as I have never seen another. The two big ports are 1/2" NPT. I believe the small port is a pressure test port but I may be mistaken. It is 1/4" NPT. Google that part number and see what happens.
third party image
