If all the gears work and the noise is only a whine, I think you would be wasting a lot of money and work to rebuild the transmission. It might still make the same noises, as some noise is normal with these. It's rare for these transmissions to give much trouble. Most common problem is the oil slinger gear which will cause a lot of noise, but not much harm. To replace the oil slinger, you have to completely take everything apart.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
