Posted by Rootsy on April 26, 2010 at 08:56:13 from (24.247.111.162):
In Reply to: Steering help posted by Janicholson on April 26, 2010 at 06:24:39:
The pitman arm has to come off before the lower half of the casting can come off... Need to remove the front axle also... It is often easier to support the tractor under the bellhousing on a jack stand and pull the whole front end off.
Once the steering shaft is out, the axle off and the pitman arm off you can unbolt it and work it apart. There are 2 locating dowels.
Once in there there isn't much. The bushing in the casting you removed... Sector gear is keyed to the shaft and has a bearing on it which is held in the upper casting by a retainer held in place with 3 bolts.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
