They are buried, but I think they may be reached via the spark plug hole. I can't remember right now about the 6. I know they can on the bigger engines. That plug hole is large (18mm) and some skinny needle nose pliers can get a hold on the stem and work it, possible enough to loosen it. The spring is only rated for 25 pounds new, so they can stick easy. Usually it takes a little up action, and then a tap down from above, repeat as needed. Don't grab up high on the stem of course, and starting with a tap down motion first helps to break it free in the first place.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
