Does it have primer cups on it? If so, make sure they are they shut. If not, take the valve cover off and make sure there are plugs in the primer ports.
One other thing to check. Make sure the valves are operating as expected. Not only from a movement, but is #1 on TDC, are the valves closed? take the valve cover off and watch the valves through a complete couple of rotations. Make sure they are opening and closing as expected. I got a rebuilt engine back from the machine shop and the cam gear was on wrong........some Einstein put the gear back on without the woodruff key, and it was 90 degrees off (4 bolts to mount the cam gear on). I cannot tell you how long it took to determine that little gem................
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
