amp gauge on my 300U
Posted by charlie M on April 26, 2010 at 17:31:17 from (70.101.104.228):
I put a new amp gauge on my 300U after my old one died. At the same time I put on a new neg battery cable (12 volt generator, neg ground) and cleaned the ground to the tractor real well. Made sure I polarize the system. When I started the tractor the amp gauge went nuts with wild swings from + to -. I thought maybe the regulator was bad but a new one didn't change anything. Now after only a few weeks I see corrosion inside of the amp gauge. Did I get a bad gauge or is something else going on.I've had the system set up for 12 volts for a long time and worked fine until the amp gauge froze up last year from sitting outside.
