Re: 1946 Farmall 330 Hydralics
Posted by IH fan on April 27, 2010 at 06:01:38 from (70.242.83.158):
In Reply to: 1946 Farmall 330 Hydralics posted by ejr-IA. on April 26, 2010 at 13:05:17:
If you had the pump rebuilt recently, was it "broken in" on a test stand? If not, you may have contaminated your system with metal shavings. I am not positive, but believe these had a gear pump like most IHs had at the time, and the last "machining operation" we did at our plant was to run them for break-in on a test machine. We had high pressure filters on the output of the pump (between the pump and relief valve) to catch the metal shavings from break-in. These filters were changed every shift due to the amount of shavings. The same thing applied in our "re-man" area as it did for new pumps.
