Re: W450 D Clutch
Posted by Andy Martin on April 27, 2010 at 13:50:40 from (199.197.2.156):
In Reply to: Re: W450 D Clutch posted by Terry Harnett on April 27, 2010 at 09:02:20:
They can stick from just sitting. It wouldn't hurt to grease the pilot bearing, but driving with the clutch down may break it loose.
Sometimes when they break loose some of the lining comes apart and since there is no place for it to go, it gets caught between the pressure plate and clutch disc and that causes the clutch to drag. it will release, but you have to start it in gear or the dragging debris will keep the gears spinning and you can't shift into gear without lots of grinding. Dissassembly is then necessary.
