Re: Worn Schwartz wide front
Posted by Cub n M in Or on April 27, 2010 at 19:04:40 from (63.170.86.177):
In Reply to: Worn Schwartz wide front posted by riverbend on April 27, 2010 at 18:02:53:
third party image
third party image
third party image
Pictures of the COMPLETE rebuild I just did on the Schwarts WFE under my MTA. The thrust bearinds were so bad the remaining rollers had eaten into the drops. Also, the outer extension tubes had rusted solid to the center section so solid that we had to use the flame/ BFH treatment. Major PAIN, but should hold up now. Those bushings can be gotten through any good bearing house. $6 each. Two thrust bearings will be close to $30/each.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
