Re: M vs Super M Block
Posted by john d on April 27, 2010 at 19:38:05 from (69.130.164.126):
In Reply to: Re: M vs Super M Block posted by Janicholson on April 27, 2010 at 18:26:17:
Super M flyweel and clutch will NOT clear the top of the Liftall unit in the M. Early Super M Liftall has a depression in the top of the Liftall casting that clears the larger clutch.
