Re: Water in hydraulics
Posted by mkirsch on April 28, 2010 at 05:39:54 from (64.80.108.57):
In Reply to: Water in hydraulics posted by jc newton on April 28, 2010 at 04:48:40:
The problem is just draining only gets MOST of the fluid. There are two hydraulic cylinders, the lines, and the pump that are still full of milky oil.
It's got to be a LOT less milky than before. If it still bothers you change it again.
You would have to completely disassemble the entire hydraulic system and drain it all out to get rid of it completely. That causes problems with seals and gaskets, plus you have to deal with getting the system re-primed and purging all the air.
Realistically, all you can do is dilute it to a reasonable level.
