Wood's 59A
Posted by Old Okie on April 28, 2010 at 07:25:19 from (75.117.232.45):
I have a 1942 farmall A with a woods 59A mower. I have mowed with this setup for 25+ years with no trouble just a few worn belts. A few years ago I broke the pullys at bottom where the belt makes 90 degree turn between PTO and mower deck. I have never got it setup right again. It throws belts & breaks belts. I have just parked it. I would like to use it. Any tip's to get setup correctly?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
