The frames or front gangs appear to be configured for an exhaust lift which you do not have. It would be mounted on the left side at the very front. You need to configure for a strict hand lift. There should be a rod from the hand lift to the front rock shaft to lift the gangs. You have the front portion of the rod. The part that is missing would slip over your front rod and connect to the rock shaft from the hand lift with a pin through the adjustment holes. There should be one for each side. You also need the tool bars for holding cultivator sweeps, hiller disk etc. I don't see those. I have a set if you need them. I do not have the "feet". I can get you pictures if you need them.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
