Re: Farnall706 loader
Posted by mkirsch on April 28, 2010 at 12:59:59 from (64.80.108.57):
In Reply to: Farnall706 loader posted by cidviscous on April 28, 2010 at 08:55:18:
The "period correct" loader for that tractor would be an International 2000 loader, though many other makes and models also fit.
In fact you can still buy a brand new Westendorf loader to fit the tractor.
How they mount depends on the loader. The 2000 loader is a bit of a chore to mount, especially if you have a wide front end. It has a big heavy frame that bolts to the tractor at the front bolster and at the rear axles.
Newer loaders are "quick attach" meaning there are some small brackets that bolt to the frame, and the loader lifts itself on to the tractor.
If you buy a used loader make sure it came off of a 706 or another similar tractor like another 06 or 56 series. Otherwise you will be stuck figuring out how to adapt it.
