Posted by Eric Fox on April 28, 2010 at 13:25:41 from (207.45.130.11):
Hi all, I have a SMD that is giving me a fit! Bought this tractor after it had sat for about 4 years, changed filters, cleaned tank and replaced with clean fuel and she fired right up. Tractor ran good in gas side and desiel pressure gauge came up to operating pressure and would switch over to desiel and ideal fine. Once you put the tractor under any load it would smoke like a freight train and bog down, so I pulled the injectors which were badly clogged and had them rebuilt. After installing the injectors now I cant get it to switch to desiel at all. I cracked open and bleed the injectors but got very little fuel. Am i missing somthing in the bleeding process? Had a local desiel mech. to look at it and he said the pump was bad but I cant see that when before the injector rebuild I had good pressure and could aleast get switched over to deseil, Any help would be much appreciated. There dosent seem to many modern desiel mechanics that understand these old machines.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
