Re: Gene Bender ..others...need cultivator help for BN..
Posted by gene bender on April 28, 2010 at 17:55:33 from (207.177.56.155):
In Reply to: Re: Gene Bender ..others...need cultivator help for BN.. posted by Lmack on April 28, 2010 at 12:00:33:
Not bieng a smart A++ You have the cult for a C,SC this cult did not fit a N or M it is for the C,SC series and is not fitted for the B series. You can make it work on the B. But you will need to drill new holes to mount. Now to lift and lower you will have to weld two pieces to the lever assy you now have as there is no way what you have now will work it just wont hook up. I have only been around these cults for 60 pluss yrs and you have a C series cult not made for the Bs or Hs and Ms.
