Posted by D Slater on April 28, 2010 at 18:14:52 from (71.164.38.78):
In Reply to: cam gear part # posted by Cub n M in OrCam on April 28, 2010 at 06:45:23:
Cub and M, when you put the hydraulic pump back on don't put the wrong bolt (one to long) in the lower inside pump mounting hole. Saw several good cam gears messed up because of that. Also puts metal shavings in the engine. Posting a picture of a damaged one because of a long bolt and its not bad compared to some.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
