Re: Poor running 340 utility
Posted by rustyfarmall on April 29, 2010 at 06:18:59 from (209.152.78.140):
In Reply to: Poor running 340 utility posted by IH1978 on April 28, 2010 at 17:51:09:
IH1978 said: (quoted from post at 17:51:09 04/28/10) I have a 340 utility that spits and sputters when it gets warm or under a load. i can idle it down and it will run smooth for a while then eventily die. But it always starts right back up and runs for while again. I have replaced condenser,pionts,cap,rotor. i have flushd fuel tank out, torn carb apart and cleaned 3 different times. I think its a fuel/intake problem cause when it starts to act up i can pull the choke out and feather it through it. Im running out of ideas. this tractor has always been a good running tractor
Fuel problems will often imitate ignition problems, and ignition problems will quite often mimic fuel problems. I think I would replace the ignition coil, and if that doesn't solve the problem, you need to remove the valve cover and check the clearance gap on the valves. You might also have a bad intake gasket that allows a vacuum leak only when the engine is warm.
