Re: 460 diesel won't start
Posted by rustred on April 29, 2010 at 07:54:13 from (72.172.100.113):
In Reply to: 460 diesel won't start posted by Larrydw on April 28, 2010 at 08:27:04:
as i said, i would give it a pull with another tractor. maybe dump some diesel conditioner in the tank. if it is gummed up badly the pump will need to go to a diesel injection shop.
