The key to remember with any suspension is that the spring sets the "ride height" and the shock absorber controls the rate of motion. So, if you sit on it (obviously without moving around) and the seat has used almost all of its travel, the spring is fatigued or has too low of a rate. If you push the seat down and quickly lift up and the seat never leaves contact with your hand on the return trip, the shock is likely worn out, as it has lost its dampening qualities. The shock absorber should resist motion. So when you lift up, the seat should return slower than your hand. Typically the shock will weaken as temperature increases, because the oil will become less viscous (thinner).
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
