by pulling the choke to keep it from stalling you are richining the air/fuel mixture which tells me that you might have a lean miss under load which in other words is a lean air fuel mixture or maybe a vacuum leak. grab a can of carb cleaner and lightly spray it around you intake mani while idling and listen (dont blow yourself up)for any increase in RPM when you hit any particular area. if you spray a spot and the rpm suddenly picks up you found a vavuum leak. if it's not that try adjusting your carm to richin the mix.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
