Farmall 100 throttle controll doesn't work
Posted by RDJ Farms on April 29, 2010 at 20:25:53 from (4.167.135.9):
Yesterday I was plowing my corn and it just went back to idle. To finish I tied the rod going to the carb back so it would run fast enough to do the job. The governor seems to still kick in. It appears to be a problem inside the governor housing. Does anyone have a idea what parts I need to order to make this repair? I didn't want to tear it down till I had the parts to fix it. Thanks for all the help in the past and the present.
