Re: International 3414 TLB
Posted by jdemaris on April 30, 2010 at 07:04:11 from (67.142.130.19):
In Reply to: International 3414 TLB posted by Tyler B on April 29, 2010 at 17:02:10:
First, you have to look at the relevant numbers. The engine tag is JUST for the engine. If it starts with "BC", then it is a BC-144 British gas engine, with a Lucas ignition and a British-Zenith downdraft VN or VNN carb (similar to Solex). British-Zenith has NO connection to USA Zenith.
Tractor serial number in on the side of the bellhosing. E.g., if it reads 3414 # 6917, then it is a 3414 tractor made in 1962.
If your tractor serial # is 2538 and has a gas engine, then it was made 1963. If it was diesel, it would be a 1961.
The backhoe is totally separate and has it's own model #, own serial #, and own parts book. It is likely to be a one of these IH hoes: 3120, 3121, 3130, 3131, 3140, or 3141 ALL used on 3414 tractors.
