Cub hydraulics (hot)
Posted by Andrew Z on April 30, 2010 at 16:24:08 from (64.252.148.52):
Im working on a Cub and the hydraulics are getting very very hot in less then 1 min or run time. I am assuming that the relief/ safety valve is stuck and causing a major restriction in the TC unit. I just want to pass that by here and see what others thought. I am using hytran oil so that is not the problem. I also do not think it is air in the system. I have rebuilt these before but never had one get to the point were you cant touch the pump or the TC unit~
thanks for the input
Andrew
