Re: Fuel Pump Problem?
Posted by tractorsam on April 30, 2010 at 19:14:56 from (24.222.151.59):
In Reply to: Fuel Pump Problem? posted by mlf on April 30, 2010 at 18:32:28:
I'm not sure about the 284, I've never played with one, but the older Farmall's respond poorly to having an inline filter installed. Is there meant to be an inline filter? On most gravity feed systems it adds too much restriction. Sam
