Re: farmall h electrical problem
Posted by John T on May 01, 2010 at 10:20:49 from (75.65.91.136):
In Reply to: farmall h electrical problem posted by Drewbee90 on April 30, 2010 at 16:25:31:
WOW only 2 to 6 volts on the BAT terminal (which is Battery voltage as Jim explained) sounds like a totally bad/flat/discharged battery. It must have been wired wrong oR she was running at the wrong polarity to discharge the battery so badly, I wonder if you installed the battery backwards??? I wonder if you fried the VoltGE REGULATOR
Id unhook the battery,,,,,,,, give it a good long charge,,,,,,,,verify if you are at Pos or Neg ground,,,,reinstall the battery and Polarize per Jim,,,,,, SEE WHAT HAPPENS
John T
