Remove the covers and take the parts out. You could also have bad seals, self explantory with the cover off. Sand the metal surfaces and replace the disks. You could also need new balls and springs, available from CaseIH. That will usually fix it. If not, OEM Tractor Parts can completely recondition for about $360. Doubt if you need to go that far.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
