Farmall Tractors Discussion Board
power steering on a I H 606
Posted by paul on December 31, 1998 at 18:37:21:
The valves in the power steering unit stick at
times nearly causing accidents when turning.
where do I have access to the hydrolic oil
bath so i could possibly add some additive to
keep the valves from sticking, and what shall I
add.
Post a Followup
: Re: power steering on a I H 606
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
