You need to pull off one of the plug wires and hold it about 1/4" away from the plug and have someone make an attempt to start the engine and see if there's good hot fire to the plug. If there's fire to the plug you need to hold your hand over the throat of the carburetor and see if there's good suction on your hand. You need good intake manifold vacuum to suck that fuel into the engine. Make sure the ignition switch is in the on position. If there's no fire to the plugs run a separate wire from the battery to your coil then see if it will start. Hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
