It sounds like you need to clean out the carb. It's not as scary as it sounds. The gas you buy today gums up pretty quick. 90% of the time one of the $20 rebuild kits from a farm supply or Napa will do the job. Get a can of carb cleaner too. Take the thing off the tractor, set it on the bench, and start tearing it down. Make notes of where stuff came from as you go. But there are only a few parts inside the old things, so there really isn't much to keep track of. Shoot the carb cleaner through all the passages, and make sure they are all open. Give the float a shake, to make sure it doesn't have gas in it. Make sure the screen in the inlet side of the carb is clean as well. Put it all back together, and back on the tractor. I can't guarantee that it will do the job, but You'll only have $25 and a couple hours invested, and GENERALLY it will solve the problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
