Re: Mower ---- Cub to A
Posted by Haas on May 02, 2010 at 17:23:16 from (75.216.1.156):
In Reply to: Mower ---- Cub to A posted by Fallon on May 02, 2010 at 16:41:44:
I assume you are talking about a Woods belly rotary mower with three blades. To move to the A from the Cub, you will need a new v belt pulley for the A, a new mounting bracket and a new belt, plus a lever lift system. By the time you buy all that stuff, it's probably easier and cheaper to find a used belly mower that has all the stuff to fit the A. Also check the rotation. I'm not sure about the cub, but most of the A mowers are left hand and discharge to the left, which means the blades spindles rotate counter clockwise and the blade bolts are left hand threads. If your cub mower is right hand, you will have to deal with that as well.
