Re: farmall 200 governor
Posted by ScottyHOMEy on May 02, 2010 at 19:01:24 from (70.105.231.15):
In Reply to: farmall 200 governor posted by les holman on May 02, 2010 at 17:11:18:
Might need a little clarification.
Is it the arm on the carb end of the governor that doesn't move? Where is your speed control lever ( the throttle lever at the seat set?)
Is that carb-end arm of the governor connected to the carb and not moving? There is an adjustment on that rod between the arm and the throttle lever on the carb that's pretty simple and may be your problem.
