Re: 966 pto psi
Posted by Owen Aaland on May 02, 2010 at 19:27:28 from (65.161.86.48):
In Reply to: 966 pto psi posted by Shannon Corcoran on May 02, 2010 at 17:40:26:
41 - 46 PSI at the feather position, 240 PSI when fully engaged. Pressure should be checked with oil at operating temperature.
You can set the pressure higher put it does put more strain on the little pin that holds the spool valve assembly together.
