Re: Wiring
Posted by Owen Aaland on May 02, 2010 at 19:38:34 from (65.161.86.48):
In Reply to: Wiring posted by 706 farmall on May 02, 2010 at 15:21:56:
When looking at the brushes, one is grounded to the case. The other goes to the (A)rmature terminal. The (F)ield terminal is connected to the field coil winding inside the case. Th other end of the field coil winding is attached to the A terminal inside the case.
