Re: 766 steering wheel removal
Posted by bc on May 02, 2010 at 21:59:39 from (71.158.218.211):
In Reply to: 766 steering wheel removal posted by kennell on May 02, 2010 at 18:11:00:
I think those all used a tapered shaft. Put a puller on it, soak it with wd, and a little heat from a mapp/propane gas torch will pop it off right into your lap. When it pops loose, it comes right at ya. Just keep the puller tite and it will come off eventually during cycles of heat and no heat. I would assume the shaft size is the same as the hole in your new steering wheel if you bought the right one.
