Posted by gene bender on May 03, 2010 at 01:30:26 from (207.177.56.155):
In Reply to: farmall 200 governor posted by les holman on May 02, 2010 at 17:11:18:
Chances are when you put it back on the output shaft has enough end play that it got moved side ways enough to make it stuck on one of the two eats that keep it lined up. Put it back on and if it happens again just move the out=-put lever sideways enough to allow it to move. You also mite want to check the pin that keeps that shaft in position itcould be worn and not long enough to allow the shaft to turn. Sometimes you need to drive that pin in a little farther so it can guide the end play better.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
