Re: SH Factory WFE
Posted by bc on May 03, 2010 at 08:28:52 from (71.158.218.211):
In Reply to: Re: SH Factory WFE posted by rustyfarmall on May 03, 2010 at 05:39:33:
Or the closest you can come to your own forge is to try covering the thing with charcoal (better yet some coal) in some type of container with the help of a hair dryer to heat the coals up a little more.
Except for an oven, most forges are an open pit pile of coal on something thick enough not to burn through and an a source from the bottom. Many small forges are made with an old old wheel hub as the focal point.
Alternatively put coal in your wood burner or lay it on the heater. I'm not sure how big it is if it would fit in the oven or not. I can get 600 plus degrees out of my gas grill with the cover closed.
