Re: 766 steering wheel removal
Posted by pete 23 on May 03, 2010 at 10:21:11 from (173.87.144.56):
In Reply to: 766 steering wheel removal posted by kennell on May 02, 2010 at 18:11:00:
The best puller I have found is a home made one. Just a stout piece of iron about half inch thick, just long enough and wide enough to fit inside wheel cap area, couple of fine threaded bolts and a bunch of washers.Drill holes in iron to span the bolt holes in wheeel. Install bolts till full thread, then back off a turn or so and add enough washers to fill the gap between bolt head and iron , tighten them down gingerly and maybe a light tap on end. Loosen nut but leave it on . Never like to heat them.
