Re: super c front crank seal
Posted by Janicholson on May 03, 2010 at 18:23:25 from (64.61.211.48):
In Reply to: super c front crank seal posted by young on May 03, 2010 at 17:57:58:
It is not going to come off without removing the front casting.
It is pressed on. It cannot be pulled with a two or three arm puller, it will break the pulley.
A plate (1/2" made in a U shape to fit behind the flange will allow a good pull. Most come off with a hydraulic jack and a socket fitting down against the crank snout. The jack pulls on the U shaped plate (above with 5/8 or 3/4" ready rod and double nuts.) If it stays in the frame, a jack that pumps when horizontal is needed, or a Porta-Power.
I had to put one in a 60 ton press to get it off, and it was almost 4 ton of pressure on the ram.
Before reinstalling, clean everything and polish it up. Inner bore and shaft both need to be shiny. Heat the pulley to ~ 200 degrees then put it on rapidly pulling it in with the threads in the crank. Be sure there is no wear groove in the pulley where the seal rides, or put the new seal in a location that uses a different spot. Always polish the shaft roundy round not along the length to keep from wearing the seal. Put grease on the seal when putting it together to prelube it on the shiny shaft. Jim
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
