If it has no TA from the factory (TA delete) it could use hydraulic oil in the system, and gear oil (80-90 viscosity) in the trans and rear drive train. If it has a non working TA I would use the Hy-tran type oil. (or its equal from other stores) it should be equal to Hy-tran, or John Deere hydraulic transmission fluid. Regular hydraulic oil in not rated for the pressure found in gear drive systems (between the teeth of the gears) and will be a bad experiment. The manual will call for the Hy-trans, but If no TA it is not needed in the trans and will save some bucks. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
